I have a plan going in my mind, installing LS6 heads and cam in my GTO.
so what do you guys think and where can i find them?
Try this link:Dark said:I have a plan going in my mind, installing LS6 heads and cam in my GTO.
so what do you guys think and where can i find them?![]()
Since you're going for the heads anyway, why not the CNC ported versions? They will require assembly and transfer across of parts (I'd recommend the new HP SS Intake hollow stem and SS exhaust sodium filled stem valves, latest springs, retainers and locks minimally) GM says they'll support up to 500 HP.Dark said:I have a plan going in my mind, installing LS6 heads and cam in my GTO.
CNC heads ok but i dont that i'm going to have any "ported" parts in my plan, i need somethin that lives longerOld Goat said:Since you're going for the heads anyway, why not the CNC ported versions? They will require assembly and transfer across of parts (I'd recommend the new HP SS Intake hollow stem and SS exhaust sodium filled stem valves, latest springs, retainers and locks minimally) GM says they'll support up to 500 HP.
A good set of aftermarket heads and a nice cam, as well as the vehicle with these mods, will last as long as the factory setup, so long as you keep care of the car and change your oil properly.Dark said:CNC heads ok but i dont that i'm going to have any "ported" parts in my plan, i need somethin that lives longer![]()
If I was gonna swap heads there is no way I wouldn't change the cam while I was at it.dryheat said:What do you think ls6 heads with stock cam and stock exhaust would give ya?
Why?JayStew said:If I was gonna swap heads there is no way I wouldn't change the cam while I was at it.
I honestly wouldn't know. I haven't seen any numbers on an LS1 for just a head swap. I think if you compared LS6 heads vs. LS6 cam, the cam would show a bigger gain on the dyno than the heads would.dryheat said:I know bigger gains can be had, I was just curious. I would probably do heads and cam but would sure like to know what could be had with just the heads.
I could be wrong, but I swear I read in an article (I'll look for it today) that the GTO already has the LS6 cam in it, or was it the Z06 cam (That’s how the engine achieved 350Hp). But I'm sure I read that GM wanted a faster launch than the stock LS1 cam would give. I remember thinking to myself after reading the article that the ‘04 GTO LS1 is a unique engine found in no other vehicle. I just can't remember where I read the Information at. Anyone know about this, what cam is in the '04 GTO LS1?JayStew said:If I was gonig thru the time and effort for a head swap, why not change the cam and see even better gains?The LS6 cam is not the same as the LS1.
LS1- 198/208 .500 lift
LS6-204/218 .550 lift
Only 1-2 hours more work for much bigger gains, especially if you go with an aftermarket cam 220 or bigger.
