St. Mary,
A skilled driver can theoretically brake shorter than ABS can, somewhere around 5-10% shorter depending on the driver's skill and the way the ABS is set up.
There's a relationship between the pressure the car is applying to the brakes, and the pressure you are applying to the pedals. Beyond a certain point, the pressure applied to the brakes is (sort of) constant, because ABS is activated. The exact slope of the graph, etc, all vary depending on the setup, what surface you're driving on, etc, but it looks sort of like this:
ABS activates when it detects the tires not spinning, but because of the way that ABS works (cycling the brakes on and off), it can't maximize the total traction of the tires. So, if you can brake hard enough to take advantage of that last 10% that ABS can't use, you can get shorter stops without ABS.
Note that this is generally true on dry pavement. On wet pavement, since the tires slip much easier, that little spike in the graph where you can outbrake ABS is much, much smaller and ABS will probably be more effective, even for skilled drivers. On snow and gravel, no ABS generally stops you better because a wedge of snow/gravel builds up in front of the locked tire and helps stop you.
All that said, though, your stopping shorter than ABS directly relies on your ability to modulate the brakes to take it up to the edge of the tires locking up, but no further. What kind of tires are you running? If you lock up your brakes, there's a good chance you'll flatspot your tires, especially if it's soft r-compounds. Are you willing to risk destroying a set of tires to gain a couple of feet in a braking zone? Are you good enough at working the brakes to avoid locking them up consistently, even while you're busy looking ahead at the next corner, yet still be braking harder than ABS would allow you to?
I think that overall, the benefits of ABS outweigh the negatives. I've done a lot of corner working, and it's pretty easy to tell who has ABS disabled or didn't have it in the first place, because they are always locking up at least one tire, smoke everywhere, usually with the tires turned but the car continuing straight because the tire can't roll.
